RE: FMS on E-bay
I have RealFlight and my Futaba radio has the round plug on the back I believe the square plug is a newer design. To work with the square plug you need to get an adapter. Your LHS may be able to order one for you or you can call Tower and they should be able to set you up. If you decide to eventually go with G2 you will still need the adapter either way.
