RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 02-17-2004 | 05:49 PM
  #2574
Archie
Default RE: RE: RE: RE: Capiche 50
Buggo - How about some pics when you are ready.... email them to IH.
Canopy... I go for a bit of cyano or a bit of epoxy to wood contact points, then use either protrim or actual film (soarspan, profilm etc) ironed into position around the canopy - this gives you a trim line and good adhesion and looks like its supposed to be there.
Im not a fan of canopoy screws either unless you actually need to have access. Carbon Cans are easy to do, its the clear ones you have to take care over, especially with cyano.
Luke PVC Tape - Shame on you...! Use some of the black film and your iron - stretch it round - much better !
Zep - Prop hanging.... those that say you need the wind are used to prophanging fun flys only. remember this is not a fun fly so it will give you more of a challenge to do this figure but also remember that when you DO do it with the C50 you are doing it for real and not cheating !
Torque rolls, unless very windy should not lean into the wind, they should be vertical and the C50 does it as well as most, but as Luke says - doing a t roll properly is down to you fingers and thumbs ! (and hald descent servos - now I have 3010s they are a lot easier = I no longer have time for a sherbert between stick inputs !)
