RCU Forums - View Single Post - 1/4 Scale Planes?
Old 02-17-2004 | 09:29 PM
Technito20
Default RE: 1/4 Scale Planes?
Hi, I know of an excellent 1/4 plane if you haven't found one already. I don't know if you are into kits or Arfs. But the best 1/4 scale plane I can suggest is the 37% Sukhoi SU 31M. This can can be built I'd say minimum of a month full time. Take a look at it. It's awesome. At http://www.lanierrc.com/lrcprivate/r.../sukhoi_37.htm.
If you don't want the kit, you can go with the Arf. The Goldberg Sukhoi 1.20 Arf. See this at http://www2.towerhobbies.com/cgi-bin...?&I=LXFGT1&P=7
I have seen these planes in action and they do the full acrobats of a scale or fun fly plane. But in huge action. The kit is much more expensive and takes long to build. I don't know if you are just getting into airplanes or not. The Arf is just as great, Some experienced flyers prefer kits so they can customize their flight abilities.An Arf is a basic plane that you will simply put together within a day or two that is already factory built. Like 70% of work done for you. Which separates kits from Arfs. And lastly a good Engine to throw on this is a Saito 120S Golden Knight. With this combination you'll be dominating the field. I guarentee it.
