RE: RE: STALLING
Hi Ken,
You say your tank is 3" behind the firewall? Any reason it's so far behind? Maybe the extra fuel line behind the firewall flops around when the plane is in motion, leaning out the fuel supply to the carb?
Your tank is extensively padded to prevent foaming, but is it rigid enough? What kind of padding are you using?
What about the opening in the firewall for your fuel intake and pressure? Is it possible it's too small and restrictive?
About the All caps thing, I do have a suggestion which might help you in all your computer applications.
Assuming you're running windows, look in your control panel for an icon called Accessibility Options.
(Start-> Settings -> Control Panel -> Accessibility Options)
Choose the Display Tab and check "Use High Contrast"
Click Settings
Here's where you can play with it. Click the Custom Option and choose a setting from the list.
I haven't tried them all, but you'll probably be able to find something easy to read.
The beauty of this method is that you'll be able to read anything on your computer clearly, yet when you contribute in a forum, you can use lowercase letters and not offend anyone.
