RCU Forums - View Single Post - jb weld coil to case??
Old 02-18-2004 | 10:22 AM
Captain351
Default RE: jb weld coil to case??
If your engine doesn't have coil mounting lugs (one of the Poulans is like this) it is far easier and more desireable to convert it to Electronic Ignition. In the long run you will be far happier with the performance and reliability if you go this route. You will also save the weight of the flywheel which you won't need anymore.
