RCU Forums - View Single Post - Need a cheap, throw around ARF: Impossible?
Old 02-18-2004 | 05:35 PM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: Need a cheap, throw around ARF: Impossible?
One last pic.
Throttle servo is Hitec HS-81. I used some flying wire straps and bent them into an angle. Then I bolted them to the servo and used small wood screws to mount the servo to my engine mount. Linkage is short and sweet.
I didn't bother with the fiberglass cowl on this plane. Not much left of it after cutting to fit around the TH .75 anyway.
Plane hovers at 1/2 throttle here in Denver at 6000' altitude. I'd think your 50 would do the job at lower elevation.
