RE: Carb setting for Quadra 35
If it's in good shape, good seals, no leaks around the carb, they usually end at one turn on the high speed and one and a half on the low speed. Thats on an 18- 8 prop.
Start off a quarter of a turn richer and work down to that. If the low speed is to lean,it will hesitate when you open the throttle quickly. Do all these adjustments after the engine is well warmed up.
