RE: jb weld coil to case??
Hey buckeyes1997! read the tread " gas fuel with glo plug, no ignition", where I experimented with gasoline/oil/methanol/ether I know it sounds complicated but believe me the engine runs even better than with its original ignition got more power and that is using a glow plug like the glo engines eliminated the flywheel and the coil, so read it and see if that will work for you, let me know what you think about it.
