RCU Forums - View Single Post - Phoenix Sukhoi engine mounting
Old 02-19-2004 | 10:38 AM
ooooo's Avatar
ooooo
Default RE: Phoenix Sukhoi engine mounting
Hi Doug,
Does this plane come with a cowl? If so......what engine are you using? 2-stroke or 4-stroke.
As far as I know.....with Phoenix models.....2-strokes can either be mounted straight up of 45 degrees. 4-stroke...definately 45 degrees and turn the carb around so that the high speed needle is up. The distance from the fire-wall to the engine bearing or back of the Spinner is 5 inches, for the .40 size planes. Hope this helps....
