RCU Forums - View Single Post - Inverted OS .61 FX Help Needed !!FAST!!
Old 02-19-2004 | 05:51 PM
lacofdfireman
Default Inverted OS .61 FX Help Needed !!FAST!!
O.K. This is probably a stupid question but I have never inverted an engine or used a fuel dot before. When I try and fuel the plane from the Fuel Dot I get fuel out of the carbeurator. This cannot be normal. How do you prevent it. I can fuel it woithout the engine cowl if I bypass the Fuel dot but if I use the fuel dot like it is supposed to work it is just pouring out the Carb. What can I do?
