 Inverted OS .61 FX Help Needed !!FAST!! >
Old 02-19-2004 | 05:51 PM
Default Inverted OS .61 FX Help Needed !!FAST!!
O.K. This is probably a stupid question but I have never inverted an engine or used a fuel dot before. When I try and fuel the plane from the Fuel Dot I get fuel out of the carbeurator. This cannot be normal. How do you prevent it. I can fuel it woithout the engine cowl if I bypass the Fuel dot but if I use the fuel dot like it is supposed to work it is just pouring out the Carb. What can I do?
Old 02-19-2004 | 05:59 PM
Default RE: Inverted OS .61 FX Help Needed !!FAST!!
Anyone know of a diagram that shows how to hook this Fuel Dot up. I could have it wrong. Or can you explain it to me in an easy way. Like Fuel Dots for dummies. Thanks
Old 02-19-2004 | 07:40 PM
If you are using a two line system and the fuel dot is plumbed with a tee, you're gonna flood the engine when fueling as you have noticed. Some people claim that if you make sure the carb is closed before fueling then you won't have a problem but it's best to have a three line system with a fuel dot on a glow engine without a pump in the carb.
Old 02-20-2004 | 09:28 AM
AirGar's Avatar
My Feedback: (7)
If you have a 2 line system, use the GP fueler. This automatically shuts the fuel off going to the carb, allowing the tank to "fill". After fueling (releasing filler fitting) it re-opens the line back to the carb.
Fuel "Dots" are designed for a separate (3rd line) for fueling only. You could "T" it as one suggested, however, I would use hemostats to pinch off the line to the carb rather than "close the carb barrel" (kind of messy ).
Hope this helped!
Gary
Old 02-20-2004 | 09:38 AM
My Feedback: (27)
What plane do you have this in? The placement of the tank has a lot to do with this type of problem. My UCD 46 was a bear when it came to this problem, put a Ironbay regulator on, no more problem. I use a Dubro filler and everything works with a smooth running engine, just my personal experiance.
Old 02-21-2004 | 11:35 PM
Thanks I will try this.
