RE: WHAT HAPPENED, Photos inside, HELP
Well at lteast it broke while on the ground. If the engine is within the reccomended size range on the box GP should replace that for you in a hearbeat. If you are outside the reccomended range you may have to arm-wrestle them a little. I think this is an obvious case of a build quality problem regardless of what was hanging on the front and a good example of why even the best ARFS should be inspected carefully before flying.
