RCU Forums - View Single Post - Kill Switch Type?
Old 02-20-2004 | 06:33 AM
stomper
My Feedback: (20)
Default RE: Kill Switch Type?
ORIGINAL: Kregg
I have a new DA150 and have a question about the kill switch needs. I already have a ElectroDynamics Fiber Optic Kill Switch that I will be using, but I also need a standard kill switch at the engine. My previous gas experience has been with the larger Zenoahs and I have always used their kill switches. This time I'm wanting to try something different.
I would like to use a HD Futaba switch (like I use on the Rx Batts) for aesthetics and because I want a switch mount with the charge jack organized together. This would make for a clean installation. Can I use this HD Rx style of switch on the ignition?
Yes you can.
The switch will simply plug in between the ignition battery and the ignition module. The lead that goes from the switch to the ignition module will have to be cut and then solder in the connector that comes with the engine.
HTH
