RCU Forums - View Single Post - CA Model Eclipse building tips
Old 02-20-2004 | 08:36 AM
swk550's Avatar
swk550
My Feedback: (76)
Default RE: CA Model Eclipse building tips
When you are using wing bolts to hold the wings in place, only one wing adjuster per side is needed, I do use two wing bolts per side. One in front and one behind the wing tube.
Picture #1 - Is an installed wing adjuster in my Fantasy. I use the slotted plywood plate and screw on the wing adjuster. After I rough align the wings, I epoxy the wing adjuster plywood plate to the fuse.
Picture #2 - This is an inside view of the wing bolts and wing adjusters from my Panacea. This shows the relative location of everything to the fuel tank and wing tube.
Picture #3 - This is a picture of the wing bolt and nylon wing nuts I use.
Picture #4 - This is the locating dimensions I used on my Panacea. I use the same locating dimensions from the wing tube centerline on my Eclipse.
ID:	103045   Click image for larger version
ID:	103046   Click image for larger version
ID:	103047   Click image for larger version
