RCU Forums - View Single Post - Upgrading Avistar engine
Old 02-20-2004 | 04:05 PM
Cessna26
Default RE: Upgrading Avistar engine
The battery is in the far back. I used a few layers of duct tape which works ok. If you use duck tape it could slide back so tape the wires together so they do not pull apart. The best would be double sided foam tape that is fairly thick so it will stick to the pushrod tubes.
ID:	103140   Click image for larger version
ID:	103141   Click image for larger version
