RCU Forums - View Single Post - Kyosho gee bee
Thread: Kyosho gee bee
Old 04-21-2003 | 03:42 PM
  #80
pipescs
Default Kyosho gee bee
To Daven
Both of my landing gear blocks came loose last year (Poor glue Joint) Just cut a 1and a half inch square hole in the top of the wing over the point where the gear sticks up into the wing. It will not show after you patch it as the hole will be covered by the fuselage. Re glue the block down and put a 3/32 balsa patch over the hole. You should not have to remove the gear or fairing.
I flew mine this week end and got in 4 langings with out a hitch. It realy is sweet when flown off the grass. as far as the pitch sensitivity, I turned my throws down last year but am easing them back up this year a little at a time.
