ORIGINAL: thomp896
I am building a GP Skybolt and I'm to the point where I need to solder the cabanes together. The question is this; the kit contains I think four short lengths of "silver wire" to wrap joints that require soldering. The problem is that none of them seem long enough for the job, so I used 2 lengths on the first joint thinking it would be easy to find more "silver wire". I can't find any "silver wire" but have found same guage galvanized steel wire, will this take and hold the acid core solder like the stuff in the kit? I would really hate for this joint to fail as it holds the top wing on...kinda crucial! Thanks sorry this is so long. Steve
Copper is better (either tinned or natural) for soldering than galvanized steel wire because of its higher heat transfer... also, I believe that heating galvanized steel can generate some dangerous fumes..?? [
HTH
Jim
