RE: Help! 5945 Servos Software Up to date?
Lee
The March 02 servos were updated; this was and is the latest software revision as far as I know. You can check on the Hitec website for specific info, at least it used to be provided with reference to this conundrum.
In any event turn on your programmer and note when it fires up if it displays the V1.03 revision tag... When you program your servos you'll want to reset them all individually of course, this will transfer the latest software proto-call and parameters into the servos digital amp... From there setup the servos to suit your needs.
