RE: Wing question?
If you can get your hands on some 2 Mil Coro it may be a better choice to build the wing from the Spadet. It is the same span & cord as the debonair wing and will work fine. I actually liked it better because it lowered the planes landing speed.
The Spadet wing may also be a better choice for your first Spad Wing from a building stand point. You may have a problem getting the leading edge of the Deb wing strait and flat unless you build a leading edge Jig before you build the wing. It is much easier to fold and glue the Spadet wing.
