RCU Forums - View Single Post - Solid rubber tires ??
Old 02-24-2004 | 05:08 PM
SAP_2000's Avatar
SAP_2000
Default Solid rubber tires ??
Hi.
Anyone knows if and where you can get solid rubber tires that replaces Robart 2 3/4 inch wheels?
On the ViperJet, I have Skymaster rims (same as Robart, but in aluminum) with Robart 2 3/4 inch tires. Problem is that the tires are way to soft, even though I have put some foam in them.
By the way... does the original Robart foam inserts make the stock tires hard enough for a 25-30 lb. jet??
I would be great if I could replace only the tires, so I don't have to a complete new set of wheels and brakes. Any info would be greatly appreciated!!
ID:	104617   Click image for larger version
