RCU Forums - View Single Post - Looking For An Arf To Match A 1.8 Engine
Old 06-13-2002 | 01:56 AM
LOUM
Default Looking For An Arf To Match A 1.8 Engine
Carlos,
Using a sullivan 8oz tank for smoke oil. Tygon fuel lines. All up weight is 10-1/2lbs. Always remember to restrict smoke all flo as much as possible (almost off) at the start and very gradually increase until you get the desired results. Too much oil in the muffler will choke the engine to a stall unless under constant full power. SLOW Experimentation will produce the desired results.
The DP Ultimate is the absolute BEST ARF I have ever seen. Only one at my field and all admire the built in super professional craftsmanship. ONLY ONE MINOR FLAW. Supplied cap screws for I struts and wheel pants are soft and cap head wears out extreemly fast. Go to DuBro screws. All else in the Kit is perfect.
Keep the dirty side down
Lou Mango
