RCU Forums - View Single Post - RAM 750+ starting parameters?
Old 06-07-2002 | 01:09 AM
RC_MAN
Default RAM 750+ starting parameters?
I'm in the process of testing my new RAM 750+. I had two faultless starts on the turbine when the ambient temperature was 80F. I tried to start the turbine today in 60F and was not successfull.
Can someone share with me the starting parameters that are temperature compensated.
The propane/butane mix is 70 - 30
I even tried starting it the old fashion way using only propane vapor but no luck off my other RAM start box. The turbine would fire and then the fire would go out after about 2 seconds.
