RCU Forums - View Single Post - Solid rubber tires ??
Old 02-25-2004 | 02:41 AM
SAP_2000's Avatar
SAP_2000
Default RE: Solid rubber tires ??
ORIGINAL: jetdriver
Hello Stallen,
In the past, I have used Robart tires on heavy planes with this method: Go to your local hardware store and find rope or cord that will fit tightly in the Robart tire. I have used both nylon and cotton cord. I tried the foam as you did and had no luck either.
Mickey:
That was a great tip!! I'll try to get solid tires, but if I can't I'll definitely use your great tip!
Thanks so Much!
