RCU Forums - View Single Post - Engine trouble
Old 02-29-2004 | 06:31 PM
FHHuber
Banned
Default RE: Engine trouble
Air leaks in the fuel lines and tank make the engine run lean... not rich.
You already pulled off the needle limiter... pull the needle and look at it. I had one needle valve that came from the factory with the actual needle portion missing. (should taper down to appx 1/128 inch dia at the tip. If it ends abruptly after the threads you found the problem.) Its a rare problem... but its happened before.
The engine is supposed to spit a fair amount of goo out the exhaust. Thats the unburned oil. The fuel has appx 16% to 20% oil by volumn. 90% of the oil does not get burned.
