RE: Engine trouble
I appreciate your replies. The amount of fuel that is coming out is way more than normal. I have taken out both high and low end needles, both seem to be ok, not exactly sure what to look for.
Troll, not sure what the spraybar is. Is that the bar that the needle seats in inside the carb? If so I watched it go in when i put the needle back in.
I was thinking it was an air leak since it was running fine and then just went bad. I have checked both lines from the tank as well as the rubber o-ring around the tank, everything seems fine.
The plane is about a year old and ran fine before so I think its broken in.
