RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 03-01-2004 | 06:16 AM
  #2782
AsM's Avatar
AsM
Default RE: RE: RE: Capiche 50
im using a APC 13x6 which is cheap and does well. Revvs a bit much for 3d so i will probably try a 14x5n. I know archie tried one and really liked it. I know archie will tell you to keep away but how about a Bolly 13.5x6? sprink is using one and it works well. About 4 quiod from steve webb.
thanks sprink for your pics, hopefully graeme can get some flyinjg ones next weekend. RE all elmbridge 4 pics, my dads on duty sat but i got a new plane so i should be able to go both days.
Yes luke i am running it rich, had a few probs with air in the fuel pipes so it wouldnt lean out much without cutting. I intend to sort them this week so hopefully it should be better on saturday. Im using duraglo afterun after each day, in thriough th4e breather tube, never had any probs yet[&:]
Red oil is all over the whole plane luke. Think this is cos my breather tube is flapping around when the engines running.
Other thing is, it drops left in a verticle climb[&:]
Think it might need a bit more right thrust. Has anyone else done this?
If so i want to do it before i do the cowl so i dont have to mess up the paint job.
Kevin if you see this can u come on sunday?
