RCU Forums - View Single Post - elev/rud.servo hookup
Old 03-01-2004 | 12:08 PM
AMB
Default elev/rud.servo hookup
I had just finished getting the control rods installed on my WM skyraiderll
put the 90 degree bend in the rod put thru the servo arms and guess
what I had tossed out the strapper keepers that go over the bend with
the empty box. then IDEA used 2 3/32 wheel collars this works great
there is nothing hanging under the servo arm to hang up on the top
of the servo case.As a matter of fact this is the route i am going in the
future with the 90 degree bend thing, you can use a little blue locktite
if worried it it will come loose If you have a problem getting at the collar
just take the arm off the servo first and no plastic to break
