RCU Forums - View Single Post - How does MVVS rate
Old 03-01-2004 | 07:44 PM
  #55
Rudeboy's Avatar
Rudeboy
Default RE: RE: How does MVVS rate
ORIGINAL: pe reivers
Check your six Wini,
Next time around, Dar will tell you even small children in Israel speak Hebrew.
P.S.
How is your .15 doing?
I received a couple of venturis/needles if you still need one.
Yeah... amazing, isn't it... I have always wondered about that... these kids must be really intelligent, speaking a language that difficult at that age... (old joke)
The .15 is fine... I will be needing a couple more thing soon (besides the venturis)... Some parts for my GRRT for instance... I had a wristpin wire clip let go during break in, so it's pretty messed up. I just bought a very fine running 1.60 gasser, want a pipe on it, but haven't decided on the MVVS pipe or a Krumscheid yet. And I am still contemplating of trying the Marine GRRT (expensive experimenting )
So you will be hearing from me soon, don't worry
By the way Pé, since we are talking MVVS here... is that a common problem, those wire clips on the GRRT? And if so, is there anything I can do about it? I mean besided buying a new liner and piston every three tanks... I don't mind spending my cash, but I don't intend to spend it all on you either...
DualdudE...
What cold? I just spent the entire weekend behind the prop of that 1.60 gasser... you get used to it after a while... the neighbours probably don't agree with that...
