RE: Avistar ARF Wing
Have you already glued it yet or is this just a trial fit? If not glued already, when you do the epoxy you put on the flat ends of the wing should fill out any SMALL gaps when the wing halves are pressed together. If its already glued.........did you use enuff epoxy?
Ed M.
