RE: Avistar ARF Wing
When I glued it, it had enough epoxy to push out of the gaps, and I had to wipe it down. I made sure to put epoxy all over the spars that touch. I used some clear packing tape around the wing to give a perfectly smooth joint. You can just barely see a crack. I just need to make sure to lay off the throttle with my 46ax.
