RE: Funtana prop
3Ddave,
I'd say your custom 13.5x4W should work fine, as long as you rebalance it after every 'shortening event'.
If you're whacking the outside 1/4 inch off the prop tips from ground strikes, you already know, but you can get taller carbon-fiber gear that will give you a bit more prop clearance.
