 Funtana prop >
Funtana prop
Funtana prop
Old 02-29-2004 | 11:07 PM
Default Funtana prop
I keep knocking the tips off my apc 14/4 making them more like 13 1/2-4 props, so I bought an master screw 13/6 what can I expect better or worse performance?
Dave
Old 03-01-2004 | 12:58 AM
Default RE: Funtana prop
I have a Master airscrew 13x6 on mine, works great.
Old 03-01-2004 | 01:37 PM
daveopam's Avatar
My Feedback: (9)
With 15% fuel mine likes the 13x4W APC. I have run the APC 13x6. It's a good all around prop. For instant thrust It's hard to beat the 13X4W. I fly a Funtana and a Pizzaz. The pizzaz even came to life with the 13x4W.
David
Old 03-01-2004 | 02:14 PM
Marcelo3DBR's Avatar
Here in Brazil i´m not finding 15x4 prop and i´m just about to put a 15x6 on my Saito 100. What do you think??
Old 03-01-2004 | 03:02 PM
Cheech's Avatar
My Feedback: (19)
ORIGINAL: Marcelo3DBR
I used the 15x6 on my Saito 100 before I got my hands on a 15x4W. The 15x6 is a good prop.
Old 03-01-2004 | 03:40 PM
Daveopman what moter are you running Im running a saito 72
Old 03-01-2004 | 09:35 PM
daveopam's Avatar
My Feedback: (9)
I am also running a Saito .72. My favorite prop on it is the 14x4W. Mine just wont give good throttle response without 30%. I would like to try the 14x4W Zinger. I just have not found one. If you can get your .72 to pull the 14x4W on 15% your ahead of me.
I fly at 2,000' and maybe that's the problem.
David
Old 03-01-2004 | 11:44 PM
3Ddave,
I'd say your custom 13.5x4W should work fine, as long as you rebalance it after every 'shortening event'.
If you're whacking the outside 1/4 inch off the prop tips from ground strikes, you already know, but you can get taller carbon-fiber gear that will give you a bit more prop clearance.
