RE: Engine trouble
Mike,
I found that there maybe mistakes on the reference to use when adjusting the 1 1/5 turns on the idle needle.
If the carb is closed completly or open 1mm as the manual suggest for idle point, there will be quite diference on the 1 1/5 turn adjust.
Which is the carb position when adjusting the 1 1/5 turns, fully closed or the idle position?
Also, someone in the field told me last time to fully open the carb and look at the needle inside. The start point for the neddle adjust shoud be when you see a very small gap between the needle and the hole where it fits in. Is this something also ok?
Nilo
