RCU Forums - View Single Post - MICROJET HELP
Old 03-04-2004 | 03:23 PM
SJN
Default RE: MICROJET HELP
well, it is quite sensitive to CG
It should fly fine when it balances EXACTLY on the small bumps :-)
When you launch, and if you hold full up elevator, it can be enough to brake, and slow down the plane so much that it never gets up to flying speed.
I use 8 Kan 1050 cells that weigh 170grams a pack
What are you using ?
