RE: Brushless Motor questions.
Okay I am liking how this is looking, I will LOSE speed with the formosa, with this setup, BUT looks like it is saying acrobatics will be great! Almost near prop hang! All I have to do is change to the STOCK Formosa 10x6 Prop...
MotOpinion - GWS - Formosa - Hacker B20 18L - 1060 Prop 2.8:1 GWS 350c "A" Gearing gearbox
25ft above Sea Level, 29.92inHg, 70°F
Motor: Hacker B20 18L; 3086rpm/V; 0.4A no-load; 0.092 Ohms.
Battery: Thunder Power TP2100; 2 cells; 2100mAh @ 3.7V; 0.022 Ohms/cell.
Speed Control: Castle Creations Phoenix 35; 0.0045 Ohms; High rate.
Drive System: Generic 9x6in Prop w/3:1 Gearbox; 10x6 (Pconst=1.25; Tconst=0.956) geared 2.8:1 (Eff=95%).
Airframe: GWS Formosa; 256sq.in; 18.5oz; 10.4oz/sq.ft; Cd=0.056; Cl=0.47; Clopt=0.66; Clmax=1.24.
Stats: 74 W/lb in; 55 W/lb out; 15mph stall; 21mph opt @ 63% (69:13, 75°F); 25mph level @ 73% (54:27, 76°F); 906ft/min @ 29.9°; -196ft/min @ -6.2°.
Power System Notes:
The full-throttle motor current at the best lift-to-drag ratio airspeed (11.2A) falls between the motor's maximum efficiency current (5.3A) and its current at theoretical maximum output (34.8A), thus making effective use of the motor.
Possible Aerodynamic Problems:
The static pitch speed (35mph) is less than 2.5 times the stall speed (15mph), which may result in reduced performance at typical flying speeds and a low maximum speed. This situation is usually acceptable for an electric sailplane or other slow-flying model.
Pitch speed can be increased by using a higher pitched and/or smaller diameter propeller, a lower gear ratio, a higher cell count, or some combination of these methods.
Aerodynamic Notes:
With a wing loading of 10.4oz/sq.ft, a model of this size will have trainer-like flying characteristics. It would make an ideal trainer, for use in calm to light wind conditions.
The static thrust (17.3oz) to weight (18.5oz) ratio is 0.93:1, which will result in very short take-off runs, no difficulty taking off from grass surfaces (assuming sufficiently large wheels), and steep climb-outs.
At the best lift-to-drag ratio airspeed, the excess-thrust (9.2oz) to weight (18.5oz) ratio is 0.5:1, which will give steep climbs and excellent acceleration. This model should be able to do consecutive loops, and has sufficient in-flight thrust for almost any aerobatic maneuver.
General Notes:
This analysis is based on calculations that take motor heating effects into account.
In-flight Analysis - GWS - Formosa - Hacker B20 18L - 1060 Prop 2.8:1 GWS 350c "A" Gearing gearbox
AirSpd Drag Lift Batt Motor Motor Input Loss MGbOut MotGb Shaft Motor Prop Thrust PSpd Prop Total Time
(mph) (oz) (oz) Amps Amps Volts (W) (W) (W) Ef(%) Ef(%) RPM RPM (oz) (mph) Ef(%) Ef(%) (m:s)
0.0 0.0 0.0 12.6 12.6 6.8 85.4 21.5 63.9 74.8 68.7 17051 6090 17.3 34.6 0.0 0.0 10:01
1.0 0.0 0.0 12.6 12.6 6.8 85.4 21.5 63.9 74.8 68.7 17051 6090 17.0 33.6 3.3 2.3 10:01
2.0 0.0 0.1 12.6 12.6 6.8 85.4 21.5 63.9 74.8 68.7 17050 6089 16.8 32.6 6.5 4.5 10:01
3.0 0.0 0.3 12.6 12.6 6.8 85.5 21.5 64.0 74.8 68.7 17045 6088 16.5 31.6 9.6 6.6 10:00
4.0 0.1 0.5 12.6 12.6 6.8 85.5 21.5 64.0 74.8 68.6 17039 6086 16.3 30.6 12.6 8.7 10:00
5.0 0.1 0.8 12.6 12.6 6.8 85.6 21.6 64.0 74.8 68.6 17033 6083 16.1 29.6 15.6 10.7 9:59
6.0 0.1 1.1 12.6 12.6 6.8 85.7 21.6 64.1 74.8 68.6 17026 6081 15.8 28.6 18.4 12.6 9:59
7.0 0.2 1.5 12.6 12.6 6.8 85.8 21.7 64.1 74.8 68.6 17020 6079 15.6 27.5 21.1 14.5 9:58
8.0 0.2 2.0 12.7 12.7 6.8 85.9 21.7 64.2 74.7 68.5 17014 6077 15.4 26.5 23.7 16.3 9:58
9.0 0.3 2.5 12.7 12.7 6.8 85.9 21.7 64.2 74.7 68.5 17011 6075 15.1 25.5 26.3 18.0 9:57
10.0 0.4 3.1 12.7 12.7 6.8 85.9 21.7 64.2 74.7 68.5 17009 6074 14.9 24.5 28.7 19.7 9:57
11.0 0.5 3.7 12.7 12.7 6.8 85.9 21.7 64.2 74.7 68.5 17011 6076 14.6 23.5 31.0 21.3 9:57
12.0 0.5 4.4 12.6 12.6 6.8 85.7 21.6 64.1 74.8 68.6 17027 6081 14.3 22.6 33.3 22.8 9:59
13.0 0.6 5.2 12.6 12.6 6.8 85.4 21.5 63.9 74.8 68.7 17051 6090 14.0 21.6 35.4 24.3 10:01
14.0 0.7 6.0 12.5 12.5 6.8 84.9 21.2 63.6 75.0 68.8 17094 6105 13.7 20.7 37.3 25.7 10:05
15.0 0.8 6.9 12.4 12.4 6.8 84.2 20.9 63.3 75.1 69.0 17150 6125 13.3 19.8 39.2 27.1 10:11
16.0 1.0 7.9 12.2 12.2 6.8 83.3 20.6 62.8 75.3 69.3 17218 6149 12.9 18.9 40.9 28.3 10:17
17.0 1.1 8.9 12.1 12.1 6.8 82.3 20.1 62.2 75.6 69.6 17299 6178 12.6 18.1 42.5 29.6 10:26
18.0 1.2 10.0 11.9 11.9 6.8 81.2 19.6 61.6 75.8 69.9 17391 6211 12.1 17.3 44.0 30.8 10:35
19.0 1.3 11.1 11.7 11.7 6.8 79.9 19.1 60.8 76.1 70.3 17495 6248 11.7 16.5 45.4 31.9 10:47
20.0 1.5 12.3 11.5 11.5 6.8 78.4 18.5 59.9 76.4 70.7 17610 6289 11.3 15.7 46.7 33.0 11:00
21.0 1.6 13.5 11.2 11.2 6.9 76.7 17.8 58.9 76.8 71.2 17745 6338 10.8 15.0 47.9 34.1 11:16
22.0 1.8 14.9 10.9 10.9 6.9 74.7 17.0 57.7 77.2 71.7 17898 6392 10.3 14.3 48.9 35.1 11:36
23.0 2.0 16.2 10.5 10.5 6.9 72.5 16.2 56.3 77.7 72.3 18069 6453 9.8 13.7 49.9 36.1 11:59
24.0 2.1 17.7 10.1 10.1 6.9 70.0 15.3 54.7 78.1 72.9 18255 6520 9.3 13.0 50.8 37.0 12:26
25.0 2.3 19.2 9.7 9.7 6.9 67.3 14.4 52.9 78.6 73.6 18455 6591 8.8 12.5 51.5 37.9 12:58
26.0 2.5 20.8 9.3 9.3 7.0 64.4 13.4 50.9 79.1 74.3 18669 6668 8.3 11.9 52.2 38.8 13:36
27.0 2.7 22.4 8.8 8.8 7.0 61.2 12.5 48.8 79.6 75.0 18897 6749 7.7 11.3 52.9 39.7 14:21
28.0 2.9 24.1 8.3 8.3 7.0 57.9 11.5 46.4 80.1 75.8 19136 6834 7.1 10.8 53.4 40.5 15:14
29.0 3.1 25.8 7.7 7.7 7.0 54.3 10.6 43.7 80.6 76.5 19387 6924 6.6 10.3 53.9 41.2 16:18
30.0 3.3 27.6 7.2 7.2 7.1 50.5 9.6 40.9 81.0 77.2 19648 7017 6.0 9.9 54.4 42.0 17:36
31.0 3.6 29.5 6.6 6.6 7.1 46.5 8.7 37.8 81.3 77.8 19919 7114 5.4 9.4 54.8 42.6 19:11
32.0 3.8 31.5 6.0 6.0 7.1 42.3 7.8 34.5 81.6 78.4 20199 7214 4.8 9.0 55.2 43.2 21:10
33.0 4.1 33.5 5.3 5.3 7.1 37.9 7.0 31.0 81.7 78.8 20489 7318 4.2 8.6 55.5 43.7 23:44
Note: Motor performance calculations take ambient temperature and heating effects into account.
Generated by MotoCalc 7.08, 3/4/2004 8:33 PM.
