RE: Walbro WT 433 Question
Les,
The carb has a pump on one side and the fuel goes to the other side to a demand regulator that will not let any fuel past it unless there is a slight suction by the engine. You may have the fuel line on the wrong one if it has two fuel inlets. One is a return and should be plugged.
Jim
