RE: PROGRAMING EPA IN RADIO
Yes, that is what the EPA settting is for. Generally, you want to get pretty close with the mechanical setting. Use EPA to fine tune. Do NOT use a long arm on the servo and then turn the EPA down a whole lot to get reduced throw. If you do this you are sacrificing resolution and not fully using the power of your servo.
