RCU Forums - View Single Post - aileron throw ultra stick problem
Old 03-06-2004 | 04:56 PM
coastiehelimech
Default aileron throw ultra stick problem
I just finished assembling my ultra stick 40. Everything went smoothly by the book. When checking my throw distance the ailerons only have 3/8 " up. and 7/8" down. The manual calls for 7/8" in both directions. Will this fly as is? The servo horns were put on the servos as close to 90 degrees as possible. However when bending the control rods 90 degrees for connection to the horns, I shortened the lenghts a little. No problem because I just unscrewed the rods from the clevis a few turns to fit the horns and still kept the ailerons at nutral. Why are my servos throwing different amounts in different directions? The alierons moved freely by hand w/ no binding before connection. Any comment are welcomed.
