3dbatix, it looks like your rudder cable rubs your servo slightly, is that working out ok for you? I ask because I can lower my servo enough to fit a 1.25" arm in there and get good throw but the cable rubs the servo slightly, about the same amount as yours does.
Sam
ORIGINAL: 3dbatixkid
hope this picture helps. I ended up moving that elevator servo hole down so that i could fit the arm pointing up like it is. I get at least 50 degrees of throw, and the planes flies great. Hope this helps.
