RE: HELP! Can't get enough elevator throw on my CA 27%
Sizam.to prevent the rudder cable touching the elevator servo,move the cable exit to lowest part of the fuse.For rudder control horn you can make it out of epoxy board or buy it and bolted to the bottom of the rudder.Beside if double bevel you get over 50 degrees.
