RCU Forums - View Single Post - Regulated Propane Valve
Old 06-12-2002 | 01:29 PM
bkf
Default Regulated Propane Valve
Originally posted by woketman
What would I need it for? I simply use a little cheapy needle type valve with my TJT 3000s, and they start every time just fine. Do some engines require a regulated flow?
You are right WM: Your needle valve is acting a bit like a regulator. 100% propane sits about twice the pressure of the mix. Propane's 200+ psi might starting popping lines. Im more interested in regulation for use with smoke and such but see no reason why it could not be used to start any turbine if it is controlled a bit. Even with the JC you fill the start tank up full and usually get a pop when starting.
