RCU Forums - View Single Post - Throttle return spring trick ?
Old 03-08-2004 | 06:54 AM
MassiveMods's Avatar
MassiveMods
Default RE: Throttle return spring trick ?
no failsafe will help you if your (not even your futaba radio) crystal pops out or fails, or for some reason power ( ie voltage) is severd from your servo you are stuffed without a mechanical failsafe. ( ie spring attached to the outer hole on your throttle horn and mounted onto one of the springs on your center diff tower )
