RCU Forums - View Single Post - ZNLine Supreme building questions
Old 03-09-2004 | 02:32 AM
Troy Newman
Default RE: ZNLine Supreme building questions
David,
#1 Have an email into Marco but its going to end up on the tube....I'm not exactly sure where he has his....but I'll pass it along when I get it.
#2 Not sure...I'm going with one servo up front.
#3 I'm using the gator phenolic sockets with PBG tubes
#4 Plugs are for the end of the wing tube sockets...So that glue doesn't get down inside the socket when you glue it in place. There is a sub rib installed in the wing...make sure your sockets go through the rib...I used a section of small music wire to locate the depth of the rib.
#6 The center socket section gets installed in the fuse. As the kit comes the socket is located in the fuse...but it doesn't go all the way across. This short span of socket acts as a former in this location. Installed it and use a couple small strips of glass cloth to attache it to the 1" stubs that are inside the fuse.....Be careful not to glue the wing tube in the fuse....I haven't done it yet but that is the idea.
This is a very new kit for the ZN guys....I'm going to doing a write up on my model to aid others in building it.
Right now I'm in the process of a possible move so it might be a couple of weeks before the model gets started...but when I start I hope to have it flying within a few weeks.
I'll pass along the details as I get them from Marco. To my knowledge there are not many of these models out there. I know my kits are #14 and #18
Troy Newman
Team JR, ZN Line
