RCU Forums - View Single Post - ZNLine Supreme building questions
Old 03-09-2004 | 11:20 PM
Troy Newman
Default RE: ZNLine Supreme building questions
I think the electric can help the CG situation a bit....The huge 3.5lbs goes so close to CG that you can just move it a bit forward or back to get the perfect CG.
I think this is a cool setup. On Tony's Partner there was a bunch of room to manuever the batts around if you wanted to.
I have been re-considering the 3421's or 9411's in the stabs..and I still think the 0.070" CF rods are the best setup for me.
I use an 8417 on the elevator. its fast speed and power are great for the snaps...Helps the breaks as the elevator moves quickly to get the wing to stall.
TN
