Be sure that when you land from a flight remember to disconnect the fuel to the carb or use a hemostat to tie the line going to the carburater. This is only necessary of you are running the engine sideways or inverted. The reason for doing this is that the fuel will still run to the carburater once you land and you may get a nasty kivk back when trying to start your engine or it may hydrolock. Talking from experience!
