Custom prop nut pics for Capn John!
Hi,
Here's those pics finally. The one pic is of one of those long necked nuts that originally went to the weedeater cable. I cut it down slightly, and drilled/threaded it all the way through. Then I drilled the prop out slightly larger to accomodate the shoulder of the nut, and put the nut on "backwards", so that the neck, or shoulder, of the nut went through the prop. The other two pics show the rest.
The sleeve with set screw that you see, is something that I picked up at the hardware store. After I cut the center out of that particular flywheel to use to mount the magnet, it turned out to be slightly small in diameter. So I found that sleeve with set screw at the hardware store, and used it over the top of my custom hub, and mounted the magnet to it.
Hope it all makes sense,
Take care,
AV8TOR
