RE: Small hummingbird throttle problem
the oneway gear wont help with this problem. the oneway will pretty much just smooth out the tail= less torque effects.
the best way to smooth out ur throttle is to open up ur tx and flip around the piece of metal that causes the clicks. thats what people to for perfect hummer hovering. takes a lil bit to get used to, but once you do you can hold altitude fine.
