RE: NEW 9C synth
Use of the Hitec Spectra on the Futaba 9C is highly questionable and illegal by both the FCC and AMA. While you may see that it "appears" to work on your channel. What you will not see without specialized measurement equipment is the increased ajacent channel interference.
If my plane got shot down by someone using this type of setup, I would be pretty upset.
