ORIGINAL: hooaa
What type of a glow plug connector fits the Nelson glow plugs, as used on the Q500 ?engine? The plug is much larger than the typical plugs.
Where may I buy one?
The glo clip that Splatt suggests is a fine one and it is what I use. However, if you don't want to spend the money on it you could just use a pair of small alligator clips from Radio Shack. Probably would cost less than $1.50.
Also, Thunder Tiger makes a plastic clip similar to the metal one Darrol Cady sells but the quality is no where near as good.
