If the end of the muffler is rotating around in flight then I'd also check to make sure that the nut and bolt that hold it together (the bolt runs the lateral length of the muffler and the nut goes on the tail end) is tight. Don't want that falling off in the middle of a flight if you can avoid it
Good luck,
Neil.
